Anyone have an idea of what controls were on this body. It originally had three P90’s. One hole is the correct size for a standard pot, there is routing for the blade switch, but the other is smaller than what is required for a standard pot.
It is a Melancon body that was once owned by someone who works or worked for Line 6. I was told it was hanging on an office wall there and took a tumble to the floor. The body was replaced and the damaged one was given to me. I repaired most of the damage so far. I am going to eventually install mini-humbuckers, because it’s what I have. Curious how only one pot controlled all three pickups. Guess only volume?
What Controls?
No idea, but I love that spalt.
The full sized pot would be a volume/tone combo.
The smaller hole is for a mini toggle engaging something like phase, boost, whatever.
Just my guess.
Just my guess.
- LancerTheGreat
- Gearlist: -Guitars-
From what I could find they did master vol and and tone, a five-way pickup selector, and the ones with switches were listed as coil-tap or split. I’d guess this was just a master volume, pickup selector (obviously lol) and then a toggle switch for reverse phase, maybe an active eq or booster, or even a toggle button for a killswitch.
I’d do a concentric pot with volume and tone on it, and since you’re doing mini-hums, pop a switch in there for coil splitting so you can pretend it still has p90s.
Good idea. Or I guess I could just drill another hole for another pot. Need to fill the trem holes, due to one being damaged. Also need to find a two point trem that will fit the same holes once drilled again. It’s an odd spacing from what I remember.
- LancerTheGreat
Hey if it’s a toughy finding a bridge to fit, you can always fill both bridge holes and drill new entirely new ones to fit whatever bridge you wanna smack on there lol.
You can do whatever you want with it right?
The switch could have been a 'sweet switch' which is basically a resistor and capacitor, set up to a fixed high pass to ground. Like your favorite tone knob setting at the flick of a switch. I installed one on a guitar i built which had limited real estate in the control cavity.
