I've said this before and now I'll say it here...
- Gearlist: Fender Lincoln Brewster Strat
PRS CU-22 Semi Hollow
Ampeg Reverberocket
If you haven't tried the INCREDIBLE value Ampeg Reverberockets from the early 90's then you're missing out! I bought mine for $300, with an upgraded Celestion A type speaker, and it is amazing! I've never played a Fender amp that is this Fender-y...can I say that? And the higher gain channel is beautiful as well! It covers everything save heavy metal. Do yourself a favor and try one if you see one. No other amp in its price point can beat it, imo. The reverb is sublime and the glassy tones are a benchmark! Rich, warm, smooth, cutting, harmonic...whatever other superlatives that I can't think of right now. I want another just in case this one goes out. Which it gives No indications that it is/will. No amp GAS since I bought this one. Equally at home with my Strat as it is with my PRS.
- Chad
Nice, you got a picture of yours?Cyfan4036 wrote: ↑Tue Aug 11, 2020 11:02 pm If you haven't tried the INCREDIBLE value Ampeg Reverberockets from the early 90's then you're missing out! I bought mine for $300, with an upgraded Celestion A type speaker, and it is amazing! I've never played a Fender amp that is this Fender-y...can I say that? And the higher gain channel is beautiful as well! It covers everything save heavy metal. Do yourself a favor and try one if you see one. No other amp in its price point can beat it, imo. The reverb is sublime and the glassy tones are a benchmark! Rich, warm, smooth, cutting, harmonic...whatever other superlatives that I can't think of right now. I want another just in case this one goes out. Which it gives No indications that it is/will. No amp GAS since I bought this one. Equally at home with my Strat as it is with my PRS.
- fullonshred
Dang Man, I didn't even know these existed, and now I want one!
Ampeg Reverberocket
I will take one tonight and get it up.Chad wrote: ↑Tue Aug 11, 2020 11:24 pmNice, you got a picture of yours?Cyfan4036 wrote: ↑Tue Aug 11, 2020 11:02 pm If you haven't tried the INCREDIBLE value Ampeg Reverberockets from the early 90's then you're missing out! I bought mine for $300, with an upgraded Celestion A type speaker, and it is amazing! I've never played a Fender amp that is this Fender-y...can I say that? And the higher gain channel is beautiful as well! It covers everything save heavy metal. Do yourself a favor and try one if you see one. No other amp in its price point can beat it, imo. The reverb is sublime and the glassy tones are a benchmark! Rich, warm, smooth, cutting, harmonic...whatever other superlatives that I can't think of right now. I want another just in case this one goes out. Which it gives No indications that it is/will. No amp GAS since I bought this one. Equally at home with my Strat as it is with my PRS.
Always a classic, underrated amp!
- OMB
Ampeg is my #1 go to tied with a Vox AC10C1. I have a Jet J12T and a Super Jet on loan to my son. I also have a 1967 Ampeg Gemini II. Great undervalued amps and yes IMO they out Fender Fender.
Some day we have to do a shootout with my underrated crate v3112. I dont care who wins. I just hope to learn something
- Gear_Junky
Thank you! I've seen these around, but never knew much about them. Any hidden risks with them? I once bought a VERY old tube amp that had drying out oil/paper capacitors and wasn't economical to repair (as I recall it). Not knowing the full history of a line it would be helpful to know if there's anything to look out for.
P.S. I also like the vintage-y look on these.
I think [mention]andrewsrea[/mention] told me as much. Some of the people at Ampeg knew what they were doing. I know Obeid Khan worked there and later designed all the amps for Reason and designed or consulted on some of the amps for Magnatone (well he still does but I don't quite understand the depth of his current involvement).
- JimyTheAssassin
Hey it’s good to see you arrived! Welcome backGear_Junky wrote:Thank you! I've seen these around, but never knew much about them. Any hidden risks with them? I once bought a VERY old tube amp that had drying out oil/paper capacitors and wasn't economical to repair (as I recall it). Not knowing the full history of a line it would be helpful to know if there's anything to look out for.
Anyways, I love old ampeg amps and have 2 of my own from the mid 60s. I’ll admit that I’m biased to the vintage Ampeg amps for many reasons. If I were looking for a reverberocket, it would be an early 60s with 6v6 or 7591 power tubes.
None the less, cheers on your Ampeg score!
- Gear_Junky
Thank you, Jimy. I am friends with a guy who is a pro electronics engineer and to him soldering is like playing to one of us. Unfortunately he's not a musician. So with a schematic he can likely diagnose and fix almost anything, but for some of the more specific stuff I might need to do the homework. I imagine that techs who have nothing to do with music/audio probably chuckle at P2P wiring, tubes, vintage type caps and whatever else doesn't technically make sense these days.
- Chad
I got a line on an Ampeg Super Rocket SR-212RT 2x12 combo amp for $360... its the same as the one on this listing...
https://reverb.com/item/26359962-new-am ... t0EALw_wcB
what do you think, should I go for it?
- JimyTheAssassin
It seems like past sales of these have been more around 500-600. This seller reaching for $1500 based on it being USA made and in perfect condition is a bit of a reach. I’d say it’s worth half that with no original boxChad wrote:I got a line on an Ampeg Super Rocket SR-212RT 2x12 combo amp for $360... its the same as the one on this listing...
