Re-NGD: Reborn as The Bluebird (a Switch Vibracell guitar)
littlebadboy
You may have already read my NGD for this guitar before. But, it has been reborn to a different guitar now, hence “Re-NGD”!
My Switch Blue Bird
Backstory…
After having Darth Paul, I did not want another guitar because it was already the ultimate guitar I have always wanted. However, one boring day... stuck at home back in July... I decided to check out Facebook Marketplace and then chanced on this...
The guitar has not been used for 15 years. The previous owner tried to learn to play the guitar on it. I got it for $100 which included an amp and a guitar stand. I sold both for $60 later on, so it was like I got the guitar for $40!
Information from the internet says that the guitar uses “Vibracell Technology”. Vibracell is a patented process of completely molding both electric and bass guitars including the neck and headstock, from the patented Switch Vibracell material creating an instrument with precise harmonic resonance and sound frequency. Vibracell allows the entire instrument to be created as a whole with complete control of neck, body weight, and density by controlling the internal cells. With the ability to control the cells we can effectively tune the body and neck to exceed the characteristics and response of those instruments made from the best available woods in the world. Additionally, Vibracell has the pure strength to withstand extreme temperature changes that affect traditional wooden bodies and necks.
Wits its unique look and make, I thought that this would be a great modification platform for a project. After an exchange of ideas with Dr.Fill (friend from another forum), a plan was drawn! I am so grateful that the doc took on this project!
And so, I present… The Blue Bird!
Image Image
It now has Gibson Firebird V mini humbucker pickups loaded on a carbon fiber faux pickguard which Dr.Fill made from scratch. All the other covers were also turned into carbon fiber faux:
Image Image Image
Image Image Image
Details
Dr.Fill was very meticulous on this project! He used tiny stainless steel washers under the p/u height adjustment screws so that they were not riding directly on the carbon fiber faux cover.
Button stainless steel allen screws were used to hold down the guard, both rear covers and the truss rod cover.
The guitar came with a tremolo bridge with roller saddles and the tuning stability of which is excellent. I preferred to turn this guitar to a hard tail. So, Dr.Fill wedged the tremolo block inside the cavity and used two large button head allen screws to hold down the bridge flush to the body. As a result, it made the guitar sustain UNREAL. He said that this guitar has some of the best sustain he ever heard from a solidbody guitar! The string action is unbelievably low!
Image Image
Electronics Wizardry - Modified Eldred Wiring with “Top Cut” ala Dr.Fill!
The 3 position rotary switch operates as follows:
Rear position: No tone control. Just the volume and 3 way Schaller switch
Middle position: Operates like any normal guitar: Volume, tone, and Schaller switch are working
Front position: Volume, Schaller, and a 39k resistor are engaged, the tone control is disengaged. This is doc’s “Top Cut” wizardy! It works excellent with the volume wide open with distortion, and with a clean amp setting when the volume is rolled back a bit.
As per Dr.Fill, the benefit of not having a cap is that when you roll the volume back even slightly, you get a gorgeous clean, sparkly tone that the traditional Eldred may not have. Even with the volume not rolled back, its almost like having 3 different guitars, one very bright with no tone circuit load, one with the tone circuit engaged, and one thats just a bit darker, and sounds amazing with some distortion, and REALLY sounds amazing clean with the volume rolled off a touch. Doc used a really nice combination of a resistor and a vintage Aerofilm capacitor for a treble bleed on the volume pot, which you can see in the pic above. The tone circuit cap is a vintage "bumblebee" .027uF cap, same as would be used on a '50's Les Paul. The volume is a CTS 490k audio taper pot with a treble bleed kit, and the tone is a CTS 280k linear taper pot. The rotary is a VERY high-quality NOS switch, same as Gibson used in the late ‘50's/early ‘60's for their VariTone circuits.
Image Image
SPECIFICATIONS:
Specifications:
Hardware
• Vibracell® One Piece Body & Neck
• Roller-Saddle Tremolo Bridge
• Grover Tuners
• Rosewood Fingerboard w/ Pearl Dot Inlays
• Carbon Fiber Faux Pickguard
• Scale: 25 1/2"
• Neck Width @ Nut 1 21/32"
• 22 Frets
Electronics (Modified Eldred Wiring with “Top Cut” ala Dr.Fill)
• Gibson Firebird V Mini Humbucker Pickups
• 3-way Lever Switch, Schaller
• Volume pot: CTS 490k audio taper pot with a treble bleed kit
• Tone pot: CTS 280k linear taper pot
• NOS Rotary switch
Image Image
Every detail that Doc did on the guitar is unbelievable! It is so pretty that I go to the guitar room to take a look at it before I sleep! (Don’t tell my wife!)
How does it sound? A demo is coming soon!
dearlpitts
Gearlist: Strat,steat,strat,agile3018,tele ,mustang
Demo please
littlebadboy
dearlpitts wrote: Sat Nov 21, 2020 4:43 amDemo please
Coming soon!
I have to say I've never heard of those and the whole vibracell concept does harken back to the "as seen on TV" genre for me, but it appears you've done a pretty incredible job with that one. And for a $60 project start-up cost, you can hardly go wrong. Dr. Fill appears to be a pretty crafty/creative guy and he does fine work. I think it looks great and hope it sounds as good as it appears, thanks for the detailed story.
dabbler
uwmcscott wrote: Sat Nov 21, 2020 10:19 am I have to say I've never heard of those and the whole vibracell concept does harken back to the "as seen on TV" genre for me, but it appears you've done a pretty incredible job with that one. And for a $60 project start-up cost, you can hardly go wrong. Dr. Fill appears to be a pretty crafty/creative guy and he does fine work. I think it looks great and hope it sounds as good as it appears, thanks for the detailed story.
I feel it's unfortunate that Switch didn't stay around longer. They really are great guitars, if a little "out there" style-wise. Nevertheless, I love my Wild IV Signature, bought on closeout.
